Enables IP forwarding over calculated MPLS LSPs to subnets learned via BGP.
Disabled.
This command enables IP forwarding over calculated MPLS LSPs to subnets learned via BGP. (Calculated refers to an LSP that only reaches part of the way to the destination). IP forwarding over MPLS LSPs must be enabled to forward over calculated LSPs. By default, IP forwarding over MPLS LSPs to subnets learned via BGP is disabled.
The following command enables BGP‘s use of MPLS LSPs to reach BGP routes:
enable bgp mpls-next-hop
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
